04 freestar water pump repair
Old Aug 30, 2011 | 01:12 PM
ralfs04freestar's Avatar
Default 04 freestar water pump repair
Does anybody know if the motor has to be dropped to replace the water pump ?
Old Aug 31, 2011 | 07:31 AM
Use Common Sense's Avatar
You should be able to replace the water pump with the engine in the vehicle. You'll just have to remove items to gain full access. If you've never done a FWD water pump, I would recommned taking pictures before and during the dis-assembly to help re-installing everything in their proper place.
Old Oct 21, 2014 | 08:32 PM
Bracsim's Avatar
negative, you just need to lift the engine about 2 inches, loosen the engine mounts, lift the engine under the oil pan and you will be able to replace the water pump, I did it in my 2004 and that's the only way to do it.
Old Oct 27, 2014 | 06:53 AM
John Renold's Avatar
Hi friends! How do I change a water pump on my ford freestar van? Can anyone guide me?
Thanks in advance
Old Jan 6, 2015 | 03:37 AM
jmil67's Avatar
Angry ford freestar
just replaced my w.p p.i.t.a but now wont crank at all,any help would be appreciated
Use Common Sense
Jul 2, 2015 12:16 AM
makuloco2000
Oct 3, 2014 02:42 PM
mattsauto
Oct 20, 2010 02:30 PM
sheebeehuh
Jan 14, 2006 01:01 PM
