2004 Freestar Headlight
Old Dec 2, 2015 | 07:34 AM
nu-supercrew's Avatar
Default 2004 Freestar Headlight
Hello, I have a 04 freestar, headlight is out, temp readout in overhead is also out. I replaced headlight but it still does not work. Please help..
Old Dec 3, 2015 | 01:23 PM
Some Ford vehicles have a separate fuse for left and right headlamps. Good idea to check with the info in the owner's manual, or just check for a defective fuse.
Old Dec 3, 2015 | 01:30 PM
Thank you, I will check.
Old Dec 7, 2015 | 04:20 AM
Use Common Sense's Avatar
Just to let you know how screwy some things can be, I had my right cornering light go out on me. Bad bulb, so I put a new one in. Put the turn signal on and it still would not work. Even turned the headlights ON, and nothing. Then I discovered that the left one didn't work. That bulb was good. Then I was like "Hummmmm, I wonder". Put a blindfold over the light sensor on the dash and what do you know...They only work when it's dark out. Wonder what engineer thought of that to drive a mechanic nuts for a while...As I say "Chasing Ducks".
2004freestarmatt
Dec 6, 2012 11:07 PM
Chem
Jul 29, 2012 12:41 PM
thedome
Jan 23, 2008 08:37 PM
saranobles
Apr 23, 2007 06:08 PM
toaster
Jul 17, 2005 03:19 PM
