2005 ford freestar limited track off light on
Old Dec 2, 2011 | 09:18 AM
wisebird's Avatar
Default 2005 ford freestar limited track off light on
hi, any one have an idea , my traccion control off light is coming on once i drive half of a block, i don know what is causing this problem. if i turn off the van it goes away, but once i drive again short distance turn on and stay on. snow is coming and it is a very helpfull system.
Old Dec 2, 2011 | 12:24 PM
Wheel speed sensors are part of the system. It might pay to check if they are all sending the correct info to the electrical brains of the system.
Old Dec 3, 2011 | 09:10 AM
wisebird's Avatar
thanks for your information. does any repair shop can check this or needs to be at the dealer, thanks
Old Dec 4, 2011 | 05:23 AM
You might ask the shop if they have the equipment to test and diagnose the system. They may be able to find the problem. Otherwise you may be better off having the dealer do it.
Old Dec 4, 2011 | 12:58 PM
dimasp28's Avatar
Hi, can be the brakes have to be done? I have the sdame issue
Old Dec 4, 2011 | 01:05 PM
dimasp28,
So much depends on the year and model of the vehicle before an intelligent answer should be suggested since all vehicles are not the same.
Old Dec 5, 2011 | 07:27 AM
Use Common Sense's Avatar
Same issue I was having with my 2004. Sometimes it would come on driving down the driveway, 1/10 mile down the road or 10 miles down the road. My 04 Limited was popping the "TRAC OFF" constantly at any speed and distance (bad brake pressure sensor switch). But it always came on. Yours could also be a bad brake pressure sensor switch. It took me about 2 months to fix. I had the part, but it took me that long to get around to actually replacing it. It's a 15 minute job if you drink a cup of coffee. Remove the air cleaner housing and MAF sensor housing/tube for access. The sensor screws into the bottom front of the master cylinder. Just unplug the sensor, unscrew it (a few drops of brake fluid will come out) and screw in a new one. Ford part number is "7F2Z9F924A". I paid $23.82 + tax at the local FORD dealer.
Old Dec 7, 2011 | 05:29 PM
diablos30's Avatar
i was having the same issue and it turned out to be the battery was on its last legs.
Old Dec 8, 2011 | 09:20 AM
wisebird's Avatar
thanks for ur information, but the lights went off by itself, just when i filled the thank with primium gasoline, anyone has has experience.The last time i filled with regular gas , it was giving me wrong message.
Old Dec 8, 2011 | 12:33 PM
Why are you using PREMIUM gasoline? All it does is causes a loss of power, mileage, greater chance of severe pinging causing damage and $$$ out of your pocket.
