2007 Ford Freestar motor suddenly stops running?
Old Apr 16, 2023 | 10:06 PM
SixSh00ter's Avatar
Default 2007 Ford Freestar motor suddenly stops running?
4.2 motor, starts and run fine, driving along it suddenly just dies. restarts ok, and I can continue the drive. It does this randomly, and not very often. I found a thread on here that's a little similar that mentions a fuel pump module might be the cause. Any one else have this problem with a Freestar?
Old Apr 17, 2023 | 12:56 AM
raski's Avatar
Check for stored codes. Fuel pump module will usually set a code. Some models have the module mounted externally exposing them to some harsh environments..Your best bet is to connect a scan tool and monitor live data during actual driving conditions and hope it acts up.
Old Apr 17, 2023 | 08:52 PM
SixSh00ter's Avatar
@raksi - Thanks for the tips on the stored codes, and attaching a scanner.
Themechanic38@gmail.com
Apr 29, 2021 08:10 PM
tkkwilb
Aug 20, 2019 09:46 PM
tkkwilb
Aug 17, 2019 03:14 PM
dankelley2000
Dec 19, 2017 06:17 PM
Doc's Place
Jun 20, 2015 10:48 AM
