Dim light, but only the drivers side?
Usually,,,,,,,,,, when that happens, that light has a poor ground connection. One of the 3 wires from the bulb assy is a ground wire. The other 2 are for hi and lo beam. The ground wire may be connected to the fender or to other sheet metal. Trace it and check where it is bolted to the sheet metal.
There could be a poor connection right in the bulb socket also.
markfothebeast
May 11, 2010 06:01 PM
darlmn
Apr 23, 2007 12:09 AM
