Door lock stuttering
Old Nov 7, 2011 | 01:00 AM
colorado2mama's Avatar
Question Door lock stuttering
Recently my driver door lock has started stuttering, it was only doing it when unlocking but tonight it started doing it when I lock it as well. Sometimes I must hit the unlock button three times to get the drivers door unlocked. Will this door lock eventually stop working alltogether? Can anyone tell me what the problem is? Is this something that only a mechanic can fix and do you know if it is an expensive repair? Thanks!
Old Nov 7, 2011 | 08:33 PM
cougar_fan's Avatar
Do you have a keyless entry system? If you do, is that power lock acting up regardless of your way of activating it (as in, remote vs door switch)? If it behaves the same, I would suspect a problem with either the lock actuator (you can get one pretty cheaply on eBay), with the relay in the remote entry unit or simply with the wiring. Take down the inside cover of the door, identify the two wires connecting to the lock actuator, disconnect them from the car's harness and try actuating it with an external battery - this should show you if the actuator is bad or not.
If the remote entry works fine but the switch is causing the stutter, then I would blame the switch - it's not uncommon to have water entered into the switch and damaging the contacts.
HTH .. let us know how it goes. Good luck!
sandman2701
Dec 20, 2008 10:23 PM
charles_tint
Aug 7, 2008 09:39 PM
RealFnCool
Jun 13, 2008 09:08 PM
brittainmcneil
Dec 29, 2006 01:56 AM
estraw
Jun 30, 2006 06:21 PM
