Front strut replacement
Hello trying to put struts on couldnt get quick struts had to change spring now cant get the strut back in the knuckle sanded all the paint off the bottom of strut and sanded the rust out of the knuckle also have ordered a knuckle spreader will b here in a couple days anyone have ANY suggestions ???
Struts issue
Originally Posted by Bikermikeyblack
(Post 101588)
One thing to mention is that you need to have the bolt out of the knuckle for the base of the strut to slide in. (I'm sure you have it out but just in case). DB |
Originally Posted by DAB6
(Post 101821)
I just replaced my struts (new struts with old springs) on my 2005 Freestar and they slid in as easily as they came out so maybe you have the wrong size strut...? Measure the diameter of the old and compare to the new ones. If they are the same diameter, they should slide in.
One thing to mention is that you need to have the bolt out of the knuckle for the base of the strut to slide in. (I'm sure you have it out but just in case). DB i put the struts in the freezer overnite and they slid right in i happen to think of that and it worked fine they must have been a little fat |
(Post 101833)
thanks DB
i put the struts in the freezer overnite and they slid right in i happen to think of that and it worked fine they must have been a little fat DB |
Great idea drilling a hole i had to do the same vice grip thing to get the nuts off also was very difficult
