How to remove fuel filter from gas tank bracket? 06 Freestar
Old Jul 24, 2007 | 09:35 PM
jcasaccio's Avatar
Default How to remove fuel filter from gas tank bracket? 06 Freestar
Hi everyone-
I went to replace my fuel filter on my 2006 Freestar van and could not loosen the bracket that holds the filter in place. It is a plastic enclosure that appears to be attached to the tank by 2 plastic rivets or bolts - though I tried to unscrew these. I am not sure how to get this thing off. Any suggestions from folks who have done this on the Freestar?
Thanks in advance!
Jack
Old Jul 26, 2007 | 03:35 PM
Jakers's Avatar
Default RE: How to remove fuel filter from gas tank bracket? 06 Freestar
Looked in my 2004 manual and it appears the filter is mounted in the middle of the van under the floor board. Don't know about the 2006 but are you sure that is the fuelfilter and if I may ask way are you trying to change it?
Old Jul 26, 2007 | 11:15 PM
jcasaccio's Avatar
If you are asking why, it's because I have 26000 miles on it and it's time.
Old Jul 27, 2007 | 09:49 AM
Jakers's Avatar
I have 60.000 miles on mine and never changed it. Some of these so called maintainanceitems aredesigned to sell more Motorcraft parts IMHO.
Coming back to the filter I had another look in the manual and I believe you are looking at the wrong thing. The filter should be in between the fuel line and is about 4-5 inches long. I believe the part close to the fuel tank is the evaporative emission cannister and the cover has a couple of push in plastic connectors.
Good luck and if everything fails check with your dealer and ask him where the fuel filter is located.
Old Jul 28, 2007 | 11:52 PM
jcasaccio's Avatar
I am looking at the fuel filter for sure. It has a plastic shroud that protects/covers it. There are 2 platic 'bolts' that hold this shroud on. I am looking to learn how to remove these bolts.
Old Jul 29, 2007 | 09:11 AM
Jakers's Avatar
If these "plastic bolts" are the type without a slot etc, meaning flat on top you just pull them out by trying to put something under them and slowly pulling them up.
I will try to send you some pictures if I can find the time.
Old Jul 29, 2007 | 12:10 PM
Jakers's Avatar
Hi. Tried to send you a couple of pictures from my 2004 manual but had some trouble uploading them to this forum.
If you would like them send me your email address and I will send them to you.
Jake
Old Sep 4, 2007 | 12:10 PM
jcasaccio's Avatar
I did get the plastic bolts out, they just pull up. The problem now is that 1/2 of the filter is hidden under the tank and it's impossible to get to. Ford really made it hard to do this usually simple job. It seems that the tank will have to be lowered a little to access the 2 fittings.
Joe Reeves
Aug 20, 2013 03:26 PM
cantthink5133
Apr 6, 2011 09:03 AM
THEGOOSE
Feb 22, 2009 10:45 PM
philn
May 27, 2008 11:48 PM
philn
May 23, 2008 07:43 AM
