Changing control arms
Hmm, not sure if this forum is still active ... Last thread was back in July ... Anyway ....
Last tire rotation, I was advised the bushings in the control arms are deteriorating. I've considered ordering new control arms and just replacing them as they have to be removed to replace the bushings anyway. I've looked at some You Tube videos and it doesn't look like that intense of a job.
My question for the "experts" here is this ... anything to be aware of before tackling this? Do's? Don'ts"
Yes replace the whole control arms. Additionally get a camber/caster kit (not cheap one under $50) otherwise alignment tech can't make any adjustment. The kit is a must buy if you don't run stock size on your wheels.
As noted at the bottom of my post in the signature area, this is an '07 Freestyle Limited, 2wd with their 3.0 engine and the dreaded CVT transmission with 235,000 plus miles on it. It has stock size rims and tires. It was aligned when I purchased the new tires just less than a year ago. There was no mention of any other parts needed at that time. I simply want to replace the lower control arms to get maximum life out of these tires.
Thank you for your suggestion for the "camber/caster kit" but, I see no need for it, running stock sized tires.
Apparently, I never got an alignment print-out. I looked through the "Vehicle Condition Reports" from the Goodyear garage that replaced the tires and did the work. All those contained was what they found to be okay, suggested repairs and what needed attention.
I also looked through the paperwork I got after the repairs. That was just receipts for the work done.
I knew it needed an alignment, especially after replacing the left tie rod ends. The work got done, I was happy with the end result so, I never questioned it.
