2011 Fusion permanent trouble codes
Old Jun 7, 2017 | 03:48 PM
flathead52's Avatar
Question 2011 Fusion permanent trouble codes
Replaced radiator after minor collision, failed to bleed airlock, car ran hot on short test drive. Now posting "High Cylinder Head Temp" permanent code. Problem fixed, no damage, operating properly, but unable to clear code with scan tool. ??????? Need advice please.
Old Jun 25, 2017 | 05:31 PM
WyrTwister's Avatar
First , are you sure the air is out of the system ?
To clear the codes , try removing the negative battery cable , then positive battery cable . Hold the ends / " clamps " together for a few minuets .
Noe just to be sure , go dring a cup of coffee , take out the trash and any othe errands .
Come back to the car & re-install the positive cable . Then re-install the negative cable .
Check to verify all sensors & such are connected securely .
Now , check for codes .
God bless
Wyr
xoFusionxo
May 20, 2013 06:41 AM
cardiag12
May 16, 2011 03:01 PM
Ronjon17
Feb 18, 2011 02:31 PM
Bronco76Ranger00
Nov 8, 2009 08:24 PM
