Brake "Christmas lights" issue, who can figure this one out!
Old 09-05-2018, 12:43 AM
Grendochan's Avatar
Default Brake "Christmas lights" issue, who can figure this one out!
I’ve recently been having a problem with my 2011 FORD FUSION HYBRID where a bunch of warning chimes come on at once. ABS, Brake system, Advancetrac all go off when the car is started after being off for awhile. Power braking turns off so all there is left is super jerky hydraulic braking that feels like I'm doing one leg squats. After it runs for a little I can restart the vehicle and the lights will all disappear and power braking will come back. Seems as if this only happens after a prolonged period of time without the engine running (about 8 hours or so).
I bought a scanner that can read ABS and SRS codes and downloaded Forscan so I could pull information from the computer, but while I’ve done drivetrain work before I have no idea what these codes are saying. I’m hoping it’s a wheel sensor but I’m kinda nervous about it being ABS, because I’m super broke and can’t afford that right now. Maybe someone can help me out?
THE BATTERY WAS JUST REPLACED. PROBLEM OCCURRED BOTH BEFORE AND AFTER SO THAT'S NOT THE PROBLEM, I know they're finicky on the Hybrids.
I’ve also attached a picture of the cluster when the lights go off.
PCM
Code: U0418 - Invalid Data Received from Brake System Control Module A
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
ABS
Code: C1B00 - Steering angle sensor
Additional Fault Symptom:
- Signal Plausibility Failure
Status:
- Test not complete
Module: Antilock braking system
Freeze Frame :
-GLOBTIM: 226026192 sec - Global real time
-TOTDIST: 155302.0 km - Total Distance
-MAINECUV: 13.75 Volt - Main ECU voltage supply
-OUTTMP: 17 °C - External Temperature From Sensor
-AYC: Inactive - AYC
-ABS: Inactive - ABS
-BTCS: Inactive - BTCS -201D
-RSC: Inactive - RSC
-BTC: Inactive - BTC
-HDC: Inactive - HDC
-VAC_BST_ST: Inactive - Active Vacuum Booster State
-BST_REL_SW: Inactive - Booster Release Switch State
-HYD_PMP_ST: Active - Hydraulic Pump State
-VPWR_ABS: 13.90 Volt - Module supply voltage
-VSS: 53.0 km/h - Vehicle Speed
Code: C0020 - ABS Pump Motor Control
- Circuit Open
Status:
Freeze Frame :
-GLOBTIM: 228076668 sec - Global real time
-TOTDIST: 157804.0 km - Total Distance
-MAINECUV: 14.25 Volt - Main ECU voltage supply
-OUTTMP: 9 °C - External Temperature From Sensor
-VPWR_ABS: 14.20 Volt - Module supply voltage
-VSS: 20.0 km/h - Vehicle Speed
- Circuit Short To Battery
Status:
Freeze Frame :
PSCM
Code: U0415 - Invalid Data Received From ABS Control Module
Status:
Module: Power Steering Control Module
Freeze Frame :
-SWRS: 0 rev/min - Steering Wheel Rotation Speed
-SW_ANGLE: -81.00 ° - Steering Wheel AngleAttached Thumbnails
atrdriver
03-27-2024 03:42 PM
12characterz
07-13-2018 05:42 PM
mrcarter9760
08-09-2011 10:40 PM
jrouse
12-14-2006 12:55 PM
Quick Reply: Brake "Christmas lights" issue, who can figure this one out!
