2016 Ford Fusion Titanium Misfire Issue
Old Jul 1, 2024 | 04:25 PM
Richy_Richin's Avatar
Question 2016 Ford Fusion Titanium Misfire Issue
A little while ago I had my check engine light come on. I pulled the code and it said that cylinder 4 had a misfire. I figured the plugs, boots, or coils were going bad since I had a little over 80,000 miles. I replaced them for all four cylinders and the code went away for about two weeks. Then the light came back on with the same code. I swapped the plug, boot, and coil from cylinder three to cylinder 4 to rule out those parts being the problem. Again the check engine light turned off for another week and a half or so then right back on with the same issue. This time it only took a few days for the light to turn off again. But faithfully after another two weeks or so, it came back on. At that point, I took it to a mechanic to have them do a pressure test and the results were: 1)140 2)150 3)125 4)133. This gave me more questions than answers. Which brings me to now. Has anyone had a fusion do this? Or does anyone have any suggestions on what to check or do next?
Old Jul 1, 2024 | 04:43 PM
Have you tried cleaning the ignition coil electrical connector and checked the wiring?
Jennglass05
Jan 24, 2021 08:15 PM
Andrew Neal
Mar 2, 2018 08:17 AM
Dewy
Mar 19, 2017 12:42 PM
djr32978
Mar 13, 2016 04:06 PM
coll0211
Dec 23, 2010 03:48 PM
