loud knocking/clunking
Old Aug 5, 2017 | 06:29 PM
msirmons's Avatar
Default loud knocking/clunking
I'm not sure if it will be worth buying for $150? It runs and drive but its super loud knocking/clunking noise can this be a spun rod bearing any tips and tricks to diagnose myself would be grateful thanks
Old Aug 6, 2017 | 04:35 AM
Depending on the year, unplug the coolant temp sensor which will throw it into open loop (no computer control) .If you can ground each plug wire one at a time, if it is a rod brg it will lessen the knock when you hit the right cyl.
You will get multiple codes from the computer, just remove the negative battery cable for 15 min , depending on the year, and the computer should reset.
Lonny
Nov 2, 2020 09:21 PM
moorebounce
Dec 29, 2016 11:16 AM
Blayne
Apr 28, 2007 10:21 PM
DIESELJOE
Mar 3, 2006 10:00 PM
Lonny
Apr 8, 2005 02:13 PM
