2003 Mustang GT popping and sputtering
Old Jul 5, 2023 | 03:11 PM
F250Project's Avatar
Default 2003 Mustang GT popping and sputtering
Have a 2003 Mustang GT that is running extremely rich, runs really rough popping all below 1700 RPM. Once I can get it past 1700 RPM it starts running better. It's a struggle to get it there. Mods are BBK TB and long tube headers. I've smoked tested and found no leaks anywhere.
Parts changed out:
MAF
Throttle position sensor
Crank position sensor
Intake Manifold with gaskets for manifold and throttle body
all injectors and fuel rail
fuel pressure sensor
fuel filter
upstream O2 sensors
Header gaskets (removed K member to do it right)
replaced plugs, with correct gap
swapped coil packs from a friend's GT, no change
Now, if I have the battery disconnected for about a day. It will start and run just fine for about 2 mins, then it starts running like crap again.
Driving behind it you can smell fuel coming from it. Seems way too rich.
Any thoughts on what's going on here?
RyanCooper
Oct 23, 2017 03:26 PM
johnrodgers
Aug 26, 2009 10:27 AM
meddicsanders
Oct 7, 2008 01:27 AM
bkriarass281
Apr 7, 2008 03:07 PM
highpowerd2003
Nov 20, 2005 11:10 PM
