87 5.0 auto/stick differences
Old Apr 20, 2007 | 01:34 PM
6663A's Avatar
Default 87 5.0 auto/stick differences
Hey group, first post here.
Looking at an 87 5.0 for my 66. I have a t-5 for it already. I would prefer a stick motor butif find an auto motor, how much is needed to convert it to a manual. Just the flywheel or do I need a matching hormonic balancer to go with it.
Thanks, JR
Old Apr 24, 2007 | 05:41 AM
91explorer12323's Avatar
Default RE: 87 5.0 auto/stick differences
Im no expert on mustangs or anything but one problem that usually comes into play as well as changing out fly wheels is that alot of times the crankshaft has to be changed also being that the pilot hole on the crankshaftfor a torque converter differ from the pilot hole for a manual transmission. Well at least that was a problem i had ran into with a oldsmobile engine i was rebuilding from the late 60's. as far as balanceing I would say there would be some rebalanceing needing done also if you do have to change out crankshafts as well, which im almost certain you will!! If you can find engine already set up for the manual trans i would recomend getting one of those cause this may turn into more then you want to fool with converting a engine set up for auto to a manual set up.
Old Apr 27, 2007 | 11:38 AM
6663A's Avatar
Well, I figured the most I would have to do is get the flywheel and hormonic balancer off a stick motor and swap it to an auto motor. I do have a late model flywheel laying around. I'll check it for balancing weight. Hoping the motor is internally balanced.
JR
Old Apr 28, 2007 | 04:18 AM
good luck to you i hope it really is that simple as far as just changing the fly wheel and harm. balance. the only time i ever tried to do what your doing turned into alot of crap i hadnt planned on.
tomtuck1960
Mar 15, 2014 06:10 PM
billbus
Nov 11, 2010 12:36 PM
00fxd
Apr 1, 2008 12:34 AM
jpizzle
May 8, 2007 03:58 AM
billybroncojr
Jun 9, 2006 10:14 PM
