A/c Component removal HELP!
Or if you want to continue to run the same routing, you can get an A/C eliminator pulley. ASP makes an aluminum A/C eliminator pulley that needs a 1/2 inch shorter belt and it can be bought from summitracing.com for $70. Part # ASP-028200. They also have a smog pump replacement pulley for about $68. Ford Racing also makes both of these parts. The FRPP a/c kit actually moves the power steering pump up in place of the A/C and costs $40 but their smog eliminator is $82.
