'04 Ranger Edge brake problem
Old May 9, 2011 | 01:27 PM
daculaguy's Avatar
Default '04 Ranger Edge brake problem
Front driver's side brake grabs. Have replaced both front calipers, front pads, driver's side hose (flex only), & master cyclinder. If you make effort to take it easy on pedal, grabbing may not occur; however, regular pressure on pedal results in front driver side grabbing too quick. Also, tried swapping out speed sensor on that wheel only- with no change. Problem is very consistent.
Old May 16, 2011 | 05:39 AM
glassman's Avatar
Since you've already swapped out the entire brake assembly on that wheel it looks like the problem may lie with either the ABS actuator, control module or hydraulic unit. All are high cost items so it might be best to have a brake shop or dealer check for ABS codes to try to isolate the problem before starting to replace components.
Akoesche
Aug 12, 2015 05:54 PM
cmcginn
Aug 20, 2010 08:07 AM
alstar80j
Oct 4, 2007 08:29 AM
joshtheatre
Feb 4, 2007 05:39 PM
skier150
Apr 23, 2006 11:37 PM
