1990 Ranger Dash
I just bought a 1990 Ford Ranger with push button 4x4. A previous owner had put in a new sterio, but had not reattached the 4x4 controls. I need to know where the bolts are that are holding the dash inplace.
RE: 1990 Ranger Dash
Before you can pull the 'bezel' that goes around everything, you need to pull out the ashtray and there are a couple of screws there behind the tray that hold the bezel, then it should just pop off.
Ah, ok. I figured that's all it would take. Now I just need to find a driver bit to fit these screws [sm=burnout.gif]
Yep, you can probably go up to an autoparts store and get a Torx bit set for cheap. I don't remember what the exact size is, but like I said you can get a set that will have it for cheap.
