1990 Ranger Dash
Old Aug 17, 2007 | 09:34 AM
Striker_Warcat's Avatar
Default 1990 Ranger Dash
I just bought a 1990 Ford Ranger with push button 4x4. A previous owner had put in a new sterio, but had not reattached the 4x4 controls. I need to know where the bolts are that are holding the dash inplace.
Old Aug 17, 2007 | 03:30 PM
techmanbd's Avatar
Default RE: 1990 Ranger Dash
Before you can pull the 'bezel' that goes around everything, you need to pull out the ashtray and there are a couple of screws there behind the tray that hold the bezel, then it should just pop off.
Old Aug 23, 2007 | 11:31 AM
Ah, ok. I figured that's all it would take. Now I just need to find a driver bit to fit these screws [sm=burnout.gif]
Old Aug 23, 2007 | 11:35 AM
techmanbd's Avatar
Yep, you can probably go up to an autoparts store and get a Torx bit set for cheap. I don't remember what the exact size is, but like I said you can get a set that will have it for cheap.
Striker_Warcat
Aug 17, 2007 09:34 AM
drw0392
Jan 13, 2006 06:48 PM
drw0392
Dec 30, 2005 03:46 AM
G.LYONS
Dec 6, 2005 09:02 PM
wailstock
Aug 8, 2005 04:29 PM
