1997 ranger 2.3 startor problems
Old Aug 2, 2005 | 12:15 PM
paco1945's Avatar
Default 1997 ranger 2.3 startor problems
I replaced my startor three times, twice with a rebuilt startor. And after a couple days it would not start. I got the slicking sound from relay. New battery relay chedked out good even put another one on. I gives me a selnoid problem. all cables are clean also. Has anyone had this problem before, I just put a new startor on monday. Can't trust that this is the problem.
Old Aug 2, 2005 | 01:29 PM
Ramrod48's Avatar
Default RE: 1997 ranger 2.3 startor problems
ok , did you have the battery LOAD TESTED ? , A low battery , even with one of the cells either low or failed will cause, the very problem stated , As Starters get older an more used they need more current to get them to work so if you have a problem in the system it makes for slow cranking , or no engagement of starter. I have seen a good many Ford starter relays fail due to a low voltage problem , what happens is the disc inside the relay just starts chattering causing it to burn the contacts., I dont know if the truck has had a starter before if not the old one lasted 8 yrs , Its very possible that you just got faulty rebuild's. I hate to say it but thats also a problem you run into with discount chain auto part store's , there are several I refuse to use for Any type automotive electric rebuilt parts - due to the fact that I have had such a high failure rate on their product,,, As you have seen you get tired of doing the same job over an over due to a faulty part I dont care what kinda warranty you get with it. If you have to do the job more than once its cost you TOO MUCH MONEY .......
David Hilton
Feb 17, 2013 10:04 AM
scfordowner
Oct 24, 2008 07:57 AM
Phil45680
Feb 11, 2008 04:02 PM
smokeater3194
Feb 20, 2006 09:04 PM
paco1945
Aug 2, 2005 07:02 PM
