1993 Ford Truck Ranger 4WD 3.0L MFI
Old 10-03-2007, 08:23 PM
xtyremenorthwest's Avatar
Default 1993 Ford Truck Ranger 4WD 3.0L MFI
I have a 1993 Ford Truck Ranger 4WD 3.0L MFI that is making noise when I get up to the speed of 60 MPH. It sounds like a Hum/Whine sound coming from the truck. I just replace the U joints that bolt to the transmission. What can be going wrong? I drive 600 miles twice a week, need to find out what is wrong with it so I'm not setting on the side of the road. Thanks for your help.
Old 10-03-2007, 09:30 PM
Default RE: 1993 Ford Truck Ranger 4WD 3.0L MFI
I would start by checking the rear end lube level. Examine the fluid also and see if it is black and nasty.
Old 10-03-2007, 10:39 PM
what kind of lube do i need for it? Do you mean the pumpin?
Old 10-04-2007, 03:09 AM
Could it be the front wheel bearing? If so are they hard to change?
Thank You
tooNz213
06-12-2012 07:50 PM
tragon
12-24-2011 06:14 PM
hilliad
07-04-2010 02:26 PM
bawalker
12-27-2005 01:52 PM
bigadecker
12-08-2005 09:33 PM
Quick Reply: 1993 Ford Truck Ranger 4WD 3.0L MFI
