2000 Ranger still making noise
Old Oct 29, 2006 | 07:19 PM
RJL88's Avatar
Default 2000 Ranger still making noise
Trying still to find the cause of an annoying intermittent chirping/squealing at the rear of the engine. At times it will get to a very loud squeal then quit or go back to intermittent. When it does make noise the best I can locate is in the area of the bellhousing. I am thinking that I may have a cracked flex plate. Anyone ever come across this problem. It would sure be alot easier to locate if it were a constant noise but it won't cooperate.
Old Oct 31, 2006 | 05:14 AM
sean08's Avatar
Default RE: 2000 Ranger still making noise
You might try inspecting the CV joints as it may be an unlikely culprit.
Old Nov 4, 2006 | 12:18 AM
RJL88's Avatar
That would be a good idea but it does this while idleing in my garage as well as when it's being driven. It appears that I am the only one with this problem so far. Thanks anyway
Old Nov 4, 2006 | 12:30 AM
Mulletman's Avatar
Manual? The throwout bearing or pilot bearing may be going bad.
Old Nov 4, 2006 | 01:13 AM
wheelsup68's Avatar
Old Nov 4, 2006 | 01:41 PM
RJL88's Avatar
Automatic trans. If it were a standard I would be convinced that it was the throw out bearing, kinda the same noise.
rich122464
Jun 4, 2008 07:19 AM
ahearn274
Apr 18, 2008 12:52 AM
yesitsfree
May 6, 2007 03:45 PM
jasonb
Mar 27, 2007 10:17 PM
ranger83
Nov 6, 2005 01:23 AM
