2002 Flashing o.d Light
Old Apr 15, 2008 | 11:38 PM
MWalker's Avatar
Default 2002 Flashing o.d Light
My o/d light has flashed a few times in the past.
I have been pulling over, shut down and restart to clear the problem.
This works for a while, then re-occurrs.
I think it may be the vehicle speed sensor because the truck runs fine and this happens so infrequently.
Where is the speed sensor on a 2002?
Is it a magnetic device also?
Thansk for any responses.[/align]
Old Apr 16, 2008 | 01:12 AM
Default RE: 2002 Flashing o.d Light
With an electronic controlled trans there is more than one possibly.. Should have the trouble code read if at all possible.. Some of the parts vendors will read the code at no cost.. It would help with some direction, and keep from replacing unneeded parts..
Old Apr 16, 2008 | 10:21 AM
MWalker's Avatar
Thanks Hayapower, I was under the impression that the lights must remain on before you could get a code reading.
I will head to a part vendor and obtain a code if possible.
Old Apr 16, 2008 | 11:59 AM
techmanbd's Avatar
ORIGINAL: MWalker
Not necessarily, some errors are stored so when you check it could be there.
tomcat5
Aug 10, 2021 05:10 PM
italianjeremy
Mar 3, 2006 10:59 PM
Cactus
May 24, 2005 12:59 PM
ajrn
Apr 12, 2005 05:16 AM
