2002 Ford Ranger Starting Problem
Old Apr 1, 2011 | 06:23 PM
matthampton22's Avatar
Question 2002 Ford Ranger Starting Problem
I Ran into a ditch not hard but enough to pop the inertia switch i clicked it back in and now when i turn the key i have power to the lights and radio all that but not even a click out of the starter when i turn the key somebody took a screwdriver n tested the starter it cranked but when i turn the key nothing any ideas ?
Old Apr 1, 2011 | 06:34 PM
PLEllis's Avatar
is it a man transmission or auto if its auto there is a switch that tells it is in park you can try moving the shifter to neutral and see if will start
Old Apr 1, 2011 | 06:39 PM
its a man transmission ive heard the auto thing but sadly its a standard any other ideas?
Old Apr 1, 2011 | 06:44 PM
PLEllis's Avatar
does it have the switch where the clutch has to be pressed in to start
Old Apr 1, 2011 | 06:59 PM
forgot to say that i have a limited knowledge of vehicles so i dont know about the switch but i know ive always had to press the clutch in to start it so i would think there prolly is something like that
Old Apr 1, 2011 | 07:16 PM
PLEllis's Avatar
im not sure where it is it might be under the dash at the pedal there is a way to unhook it i dont know how. but im sure sombody on here can tell you how to check it. if thats not the problem somebody will have another ideal maybe
Old Apr 1, 2011 | 07:18 PM
ok so you think it might be the clutch switch?
Old Apr 1, 2011 | 07:31 PM
PLEllis's Avatar
not sure but i would try to check it .also look and see if any loose wires going to starter selnoid ( excuse the spelling)
Old Apr 1, 2011 | 07:36 PM
thats cool ill have to look up what that is but ill try to check it out
Old Apr 3, 2011 | 05:10 PM
hurstbrian38340's Avatar
make sure the little wire is still attached to solenoid
dankhar
Aug 29, 2013 09:41 AM
FL3471
Mar 9, 2013 02:45 AM
henro
Jan 26, 2013 05:12 PM
W1UXI
Aug 10, 2009 07:00 AM
beat1970s
Sep 9, 2006 11:44 PM
