93 Ford 4X4 problems in front end
Old Nov 1, 2007 | 08:20 PM
bssfiler's Avatar
Default 93 Ford 4X4 problems in front end
I have a sad noise when I go into 4 wheel drive, sounds like pinion gears banging but it seems to be in the driver's side front wheel hub. With both front tires off it's quiet until u push in the drive shaft on the passenger side and activate the driver's side drive shaft. I switched automatic hub cups from side to side but it's still the driver's side that makes the noise. Is there a spring or clip in the differential that is on the driver's side shaft? Or do I need new hubs?
Old Nov 2, 2007 | 01:03 PM
bssfiler's Avatar
Default RE: 93 Ford 4X4 problems in front end
there's 2 round springs that fit over a sleeve on the axle and each side only had one of these springs, plus I replaced the hubs and now all is well. I think the problem was these round springs all along, not the automatic hubs.
louis olivier
Aug 30, 2011 04:29 AM
jeffswav
Jun 8, 2011 07:42 AM
anwalt
Oct 9, 2010 04:42 AM
bmarnall
Aug 15, 2009 07:10 AM
paul morrisino
Jul 14, 2009 04:40 AM
