94 abs blockage
Has anyone had the abs module block pressure from gettint to rear brakes?
RE: 94 abs blockage
I dont think it would be a blockage.[hr]The pump puts out high pressure.[hr]If anything it would be a pump failure and the light would be on.[hr]Is the ABS light on?
RE: 94 abs blockage
Good pressure out of master cylinder.No rear brakes. Using hand vac bleeder, getting no fluid at rear wheels.
RE: 94 abs blockage
What vechcle do you have?
RE: 94 abs blockage
94 b4000 mazda{it's a Ford under the hood}. no abs light on. Getting no hyd. pressure at rear wheels.
RE: 94 abs blockage
Then it has just rear ABS correct?[hr]Also did you check the fuse?[hr]And are there any kinks in the line?
RE: 94 abs blockage
No kinks. All lines look good.
RE: 94 abs blockage
ABS module did go bad. Will block fluid from getting to rear brakes. Cost just over $100
