94 abs blockage
Old Sep 19, 2006 | 12:31 AM
gclimer's Avatar
Default 94 abs blockage
Has anyone had the abs module block pressure from gettint to rear brakes?
Old Sep 19, 2006 | 01:09 AM
94 4x4 ranger's Avatar
Default RE: 94 abs blockage
I dont think it would be a blockage.[hr]The pump puts out high pressure.[hr]If anything it would be a pump failure and the light would be on.[hr]Is the ABS light on?
Old Sep 19, 2006 | 01:16 AM
gclimer's Avatar
Good pressure out of master cylinder.No rear brakes. Using hand vac bleeder, getting no fluid at rear wheels.
Old Sep 19, 2006 | 01:19 AM
What vechcle do you have?
Old Sep 19, 2006 | 01:24 AM
gclimer's Avatar
94 b4000 mazda{it's a Ford under the hood}. no abs light on. Getting no hyd. pressure at rear wheels.
Old Sep 19, 2006 | 01:33 AM
Then it has just rear ABS correct?[hr]Also did you check the fuse?[hr]And are there any kinks in the line?
Old Sep 19, 2006 | 01:39 AM
gclimer's Avatar
No kinks. All lines look good.
Old Sep 19, 2006 | 06:28 PM
gclimer's Avatar
ABS module did go bad. Will block fluid from getting to rear brakes. Cost just over $100
Hutch64
May 31, 2007 09:21 PM
jessie3
Aug 2, 2005 10:15 AM
gmm
Jul 12, 2005 07:35 PM
Cactus
May 24, 2005 12:59 PM
redfish32
Mar 20, 2005 11:31 AM
