94 Ranger clutch/transmission problem
Old Feb 24, 2009 | 07:25 PM
942.3ranger's Avatar
Default 94 Ranger clutch/transmission problem
Went to start my truck and it was stuck in gear(wouldn't pull into neutral from 1st), ended up wiggling it loose, but wouldn't go back into gear with clutch depressed. I changed the master cylinder, clutch pressure plate and disk, pilot bearing and slave cylinder. Still won't go into gear. Maybe the hydraulic line is bad? Maybe the transmission? Any help appreciated. Bled the **** out of this thing.
I can watch the slave operate from a view hole on the transmission and it seems to travel about 1/2 inch, is this normal?
Can't figure out why it isn't working. Pedal feels decent, not rock solid though. Had bled the master using a napa method before install. Autozone site recommends replacing the hydraulic hose/line and not using the quick connect (haven't done this). I've dropped the tranny twice and I'm running out of ideas. Retorqued the bolts that hold the clutch to flywheel because I had read the book specs were low.
makuloco2000
Jul 22, 2014 08:33 PM
jmelees
May 17, 2012 02:38 PM
cyberrkatz
Jul 7, 2010 09:46 PM
skid2964
Sep 27, 2009 02:29 PM
fix55it
Dec 5, 2008 01:32 PM
