95 ford ranger steering gear box help!
Old Dec 27, 2007 | 11:24 AM
projectprerunner's Avatar
Default 95 ford ranger steering gear box help!
okay guys im new here but a long time member to the harley forum. anyways my ranger steering box is going out i think i noticed i started getting a lot of play and then its gotten to a point where when im on surface streets if i hit a rut or uneven part of the road my steering wheel and tires start to shake and i thinkits because of this play. has this ever happend to any of you? if so how hard was it to change out the steering gear box? is a day or two enough time? thank you all in advance
Old Dec 27, 2007 | 11:32 AM
Default RE: 95 ford ranger steering gear box help!
oh also i noticed the tie rod ends are worn out now because of the shaking. is it possible this would cause the shaking to get worse.
Old Dec 27, 2007 | 12:54 PM
oldtimer35's Avatar
The tie rod ends could be the entire problem. You need to check for slack in the gear box, of course with bad tie rod ends, it makes it a little difficult. I would replace the tie rod ends first and then see how bad the gear box is.
Old Dec 27, 2007 | 01:37 PM
ill replace those and go from there. but how difficult would the gear box replacment be?
Old Dec 27, 2007 | 04:06 PM
oldtimer35's Avatar
The gear box isn't hard to replace, if you have the tools. The hardest part is to get the pitman arm off the gearbox. It takes a special puller because of the force it is torqued to.Also, be careful not toturn the steering wheel while the gearbox is disconnected. If you have an airbag, you can destroy the clockspring.
BaaRamEwe
Jan 29, 2020 08:10 PM
larryzzzz
Sep 8, 2014 11:26 AM
itismej
Aug 10, 2014 09:30 PM
ac917x
Dec 18, 2011 12:02 AM
mikeregister
Apr 19, 2011 08:05 PM
