96 Ranger Headlights
Got a 96 ranger and headlights aren't working. All other lights work fine "everything" blinkers, brake lights, hazard lights, parking lights everything. All the fuses are fine can't find any relays. Changed the main light switch and multifunction switch. Still nothing have been trying to trace it out it's just a pain just looking for some help.
Have you checked for voltage at the light bulb connectors?
I assume this is about the low beam, does the high beam lights work or are they also inop. Do you have a multimeter that you know how to use? |
There won't be a fuse for the headlights. There will be a circuit breaker in the circuit. Your manual should direct you to its location. A bad ground can kill the headlights too.
Do you have any kind of test equip, like a simple test light?
