96 Ranger Headlights
Old Jul 7, 2021 | 05:10 PM
2ranger's Avatar
Default 96 Ranger Headlights
Got a 96 ranger and headlights aren't working. All other lights work fine "everything" blinkers, brake lights, hazard lights, parking lights everything. All the fuses are fine can't find any relays. Changed the main light switch and multifunction switch. Still nothing have been trying to trace it out it's just a pain just looking for some help.
Old Jul 7, 2021 | 08:18 PM
scott.butler4's Avatar
Have you checked for voltage at the light bulb connectors?
I assume this is about the low beam, does the high beam lights work or are they also inop.
Do you have a multimeter that you know how to use?
Old Jul 9, 2021 | 04:36 AM
raski's Avatar
There won't be a fuse for the headlights. There will be a circuit breaker in the circuit. Your manual should direct you to its location. A bad ground can kill the headlights too.
Old Jul 9, 2021 | 07:59 AM
Do you have any kind of test equip, like a simple test light?
Bovine wrangler
Apr 7, 2014 10:29 AM
71Torino
Jul 16, 2011 12:38 PM
coachscott1
May 22, 2006 10:50 AM
EJ
Dec 29, 2005 01:05 PM
piper42
Apr 20, 2005 06:55 PM
