code 1443
Old Aug 30, 2006 | 09:28 PM
bill's Avatar
Default code 1443
code 1443 says its about the evaporative system. could this be a pluged canister or hose off of the charcoal filter of the fuel system and where is it located is it still put in the lower left side under the hood this is a 96 4.0liter ranger thank you for the help
Old Aug 30, 2006 | 09:39 PM
94 4x4 ranger's Avatar
Default RE: code 1443
I have a 94 and it is on the lower left under the hood.I would look for a vacuum line off.
Old Aug 31, 2006 | 08:24 AM
bill's Avatar
thanks 94 4+4
Old Aug 31, 2006 | 11:24 PM
Mulletman's Avatar
P1443............................
Possible causes...........
Blocked fuel vapor hose between EVAP canister purge valve and FTP sensor.
Blocked fuel vapor hose between EVAP canister purge valve and engine intake manifold.
Blocked vacuum hose between EVAP canister purge valve-solenoid and engine intake manifold.
EVAP canister purge valve stuck closed (mechanically).
Diagnostic Aids
Check for blockages between the fuel tank, EVAP canister purge valve and engine intake manifold. Check obstructions in the EVAP canister purge valve diaphragm and ports.
Old Sep 2, 2006 | 03:21 PM
bill's Avatar
thanks mulletman ill chech it all out
maineman
Aug 11, 2018 08:23 PM
cwildkats
Dec 27, 2012 09:59 AM
