Fuel Filter couplings
Should look like these.. Squeeze the small tabs at the bottom of the clip legs in toward each other and slide the clip partially out..
[IMG]local://upfiles/6756/34C93E857CF74E9B8D4C5B46F0C58B10.gif[/IMG]
By the way, it takes a special tool that clamps over the hose and you just push it into the thing, there is a spring inside or something and it releases them enough so that when your pushing it gets over the end of the filter... the OTHER SIDE, though, with only one line, was exactly as you described it... what a pain, though... just for a fuel filter!
