Fuel Line Connections
Old Oct 9, 2006 | 04:50 PM
RJL88's Avatar
Default Fuel Line Connections
Ok, I have removed my fuel tank to replace what I think is a faulty pump. Everything has gone smoothly with one exception. The connector on the output line is different from the other connectors it has a green colored clip that just had to break into 3 pieces while I was removing it. Can anyone tell me if that clip is replaceable without buying a complete new fuel line. And why the heck do they use such lousy connectors and plastic tubing to begin with? Cost?? Would it be an issue to replace the entire line with a real fuel hose and clamps or is there a pressure issue. Are these clips a dealer only item that have to be ordered making a person wait a week for them or can they be had a local parts shops? Gotta love these new trucks! Until they need to be worked on...[:@]
Old Oct 9, 2006 | 08:41 PM
94 4x4 ranger's Avatar
Default RE: Fuel Line Connections
You should be able to get these at the auto part's store.[hr]When I replace ford filters I ask the for the clips too.
Old Oct 9, 2006 | 10:34 PM
masterexploder's Avatar
i'm pretty sure that you are going to have to replace the entire line they generaly dont sell the clips, and the ones you can get with the fuel filter won't fit the ones on the tank, sorry, but you should at least try and see if they can sell an indavidual clip.
Old Feb 3, 2007 | 01:35 AM
maze1315's Avatar
I destoyed the stupid clips trying to reinstall my tank after replacing a bad float on my fuel sender. I took a 3/4 fueline hose, one GOOD clamp over the sender end and one GOOD clamp over the end of the hose, absolutely no leaks.
96 Ranger 2.3l 5sp 166kmi
JakeF150
Jan 5, 2008 06:57 AM
chester
Sep 28, 2007 06:47 AM
chughes
Jul 5, 2007 03:57 PM
splkevin
May 29, 2007 07:29 PM
gwald
Mar 26, 2006 01:09 AM
