Idle 500-1000 rpm ?
Old Sep 5, 2008 | 03:30 AM
ranger gsi's Avatar
Default Idle 500-1000 rpm ?
Hi
My Ranger idles cold between 500-1000 rpm.
Is a 3.0 1994. TPS?IACV?
Is over when you put it in driver.
Anybody had that with their Ranger?
Also starts ruff ,turns over twice and stalls.
But runs good when warm.
Had plugs ,wires ,distrbt cap,roter,all filters ,oil changed.
Is it fuel pump,sensors ,valve s,vacuum,eci,tps,icv ore whatever?
Thanks for the help.
[IMG]local://upfiles/17484/FA8F1EE6602F450791EF63CA60BC3E6A.jpg[/IMG]
Old Sep 5, 2008 | 11:51 AM
tomb1269's Avatar
Default RE: Idle 500-1000 rpm ?
Find the specs to test the IAC with an ohm meter, and I will bet your are close or out of spec.
Old Sep 8, 2008 | 06:29 PM
ranger gsi's Avatar
Ill see if i can find those specs somewhere.
Cleaning it didnt help much.
Ill let you guys know.
Old Jan 17, 2010 | 01:38 PM
ranger gsi's Avatar
Anybody got the specs ,
it still runs like that lol
Old Jan 18, 2010 | 02:27 AM
JackEmHigh's Avatar
unplug your TPS and see if it changes the way it runs, if it doesnt, that would be your problem, if it does......continue your search LOL
Old Jan 20, 2010 | 01:46 PM
digital_diversion's Avatar
check your IAC for proper mechanical operation....
disconnect IAC from engine but leave wire harness connected...look inside.....is it clogged with black carbon deposits? if so...clean it out as described below
have someone turn ignition on and off (dont start engine) while you watch to make sure the small shaft moves inside IAC to seal the channel...It wont very much but it WILL move....if it is stuck then clean it out
if it is stuck...use carb cleaner and a little WD40 to clean and lube it...use a small screwdrive to free up the IAC shaft by prying against the larger piece attached to the top of the shaft....DONT pry hard or you could damage it...just free it up if its stuck..clean deposits off...on/off ignition test it again for movement...
replace if shaft is stuck
Old Jan 20, 2010 | 02:05 PM
trev0006
Oct 16, 2010 03:14 PM
Streakfury
Apr 23, 2008 06:37 PM
Bullitt94
Feb 4, 2007 01:25 PM
gigamight
Apr 27, 2006 12:58 AM
toaster
Jul 19, 2005 07:26 AM
