It might start, It might not? 94 4.0 2wd 5-spd
I noticed that if the "Check Engine Light" does not light up when key is turned on, it will NOT start, turns over but wont start. If light comes on, I know it will start. Could this be a relay or sensor going bad? And when it does start, it runs fine and no "Check Engine Light". Anyone got any ideas? Thanks :confused:
A faulty EEC relay could cause this problem.
EEC tip
Thanks, I will go ahead and try that after work being it is inexpensive. The thing is, as I said, sometimes the light comes on and sometimes it don't so I guess I will only know that it corrected the prob if it never does if again. Or maybe I should wait until it fails to start again and change the EEC at that moment and see if it helps? After it sits a little while, it will eventually start back up. I'm all ears for any other suggestions. Thanks again with the EEC tip.
So far so good Hanky, Thanks
I replaced the EEC relay and turned the key on and off many times with the CEL lighting up every time, so I started it and went for a ride. Stopped and turned key a few times again with good CEL results again. Started it and drove it some more and stopped it and started it a few more times with no more probs so far. :) Thanks a million Hanky!!! Before I changed the relay, I tried key and CEL lit up the first time. It failed the 2nd and 3rd time and that's when I changed it.
You're welcome ! Another lucky shot!
I dunno about luck, I'd guess that you been around this a time or two. I appreciate it.
If you read this forum a lot you will gain a lot of knowledge from many experienced folks here. That's how we all learn aside from the school of hard knocks. Thanks for answering if the suggestion was helpful or not. We always appreciate that.
