My 2001 Ranger has a "clunk" in the front end
Old Jul 18, 2006 | 11:54 PM
cscottyn.1's Avatar
Default My 2001 Ranger has a "clunk" in the front end
I have a 2001 Ranger, 2wd, 2.3 L engine, 42,xxx miles. After driving for a few miles, I feel a "clunk" in the front end. It does not do this when cold, and it seems to be coming from somewhere in the front end when driving straight (not just when braking) and even does it on smooth, paved road. It is audible, but is easier felt than heard. Any ideas?
Old Jul 19, 2006 | 02:34 PM
94 4x4 ranger's Avatar
Default RE: My 2001 Ranger has a "clunk" in the front end
is it bump related???
Old Jul 21, 2006 | 12:08 AM
cscottyn.1's Avatar
No, it doesn't seem to be related to bumps, but that doesn't mean it's not in the suspension. It does it even on smooth, paved road; and I only notice it after it heats up and I've driven a little ways. I'm sure it's in the front end, but everything underneath appears to be tight. Any ideas?
Any insight would be greatly appreciated. This is my third Ranger and I've never encountered this problem before.
Thanx
Old Jul 23, 2006 | 10:53 AM
If you say it comes from the front end i would suspect the radius arm bushings.This drove me nuts on my truck.If it is the radius arm bushings you will feel it on the floor board when hitting the slightest bump.It took me a long time to find out where the noise was coming from.If that is not it I would take it to a shop for a estimate.Or take it for a alignment and explain this situation to the tech.
Old Oct 25, 2006 | 01:28 AM
Ranger96's Avatar
I had the same problem. My 96 Ranger needed new radius arm bushings and I got them changed myself. Although, it's started making a clunking noise again. Only on driver side. and yes, it is audible through the floorboards and annoying as hell!!!
Old Oct 29, 2006 | 07:43 PM
floyd's Avatar
is it coils or torsion bars?
Old Oct 29, 2006 | 08:55 PM
billj818's Avatar
It may be the radius arm bushings, but also could be the inner tie rods. If you find it is not the radius arm bushings, try disconecting the outer tie rod ends, spin the inner tie rods about 10 times to losen up the grease in the knuckle that conncts the inner tie rod to the steering rack gear. The grease sometimes dries out in one area, and spinning may help. If this gets rid of the noise, you should concider replacing the inner tie rods down the road.
Old Oct 31, 2006 | 05:47 AM
sean08's Avatar
Would it be a busted CV joint or hub?
ptotoole
Nov 30, 2017 09:44 AM
billj818
Oct 23, 2017 07:14 AM
hollooway f150
Feb 5, 2013 06:41 PM
kiarasue
Sep 21, 2006 01:09 PM
KingCobra
Aug 15, 2006 06:32 PM
