Problem HELP!! PLZ!!!
Old Jan 5, 2008 | 09:08 PM
meangreen2's Avatar
Default Problem HELP!! PLZ!!!
Got a 2000 Ranger 3.0 Flex Fuel. All Kinds of problems.
1. Wont start unless you press the gas then turn the key?
2. Rough Idle
3. Flushed the radiator and replaced coolant and now the temp. reads its overheating but its not overheating?
Old Jan 9, 2008 | 05:53 PM
peanut2008's Avatar
Default RE: Problem HELP!! PLZ!!!
Could be idle control sensor.Simple to change only 2 bolts and 1 plug.When you have it off check to make sure both holes are open,if that don`t help check air flow sensor and EGR valve.
Old Jan 10, 2008 | 12:02 PM
oldtimer35's Avatar
You can clean the iac to be sure that is your problem. Take some carb cleaner and spray into both ports of the iac once you remove it. Let it soak for about 15 minutes and then just start cleaning it with the spray. If that fixes your problem, it will be fixed for a while, so you don't have to buy one to find out.
Old Jan 10, 2008 | 12:30 PM
oldtimer35's Avatar
Now for the rest of the problems, your cooling system probably has air in it. With the newer design radiators, heater cores and degas bottles, filling a system has gotten to be fun. There is a tool now to pull a vacuum on the cooling system and then inject coolantwith the same tool. Works like charm. And you don't have to come back and fill and fill and fill, the system. As for the rough idle, has it always been rough and how rough? Do you have a check engine lite on? 3.0L engines do not idle real smooth. Is it a miss, or you just expect it to idle smoother?
delona
Mar 9, 2007 07:57 PM
berbaby
Jan 10, 2007 05:19 PM
Tony_8
Apr 15, 2006 06:06 PM
earthworm
Feb 20, 2006 12:42 AM
misseegee
Jan 20, 2006 02:26 AM
