Ranger won't start
Old Jan 22, 2022 | 03:58 PM
ldpayne1962's Avatar
Default Ranger won't start
I have a 2003 Ford Ranger with a 3.0 flex. It started with no problem but wouldn't run faster than 20mph. I replace the injectors now it won't start. What could be the reason?
Old Jan 23, 2022 | 05:49 AM
raski's Avatar
You had better luck with your old injectors which likely were not bad. Put the original injectors back in and diagnose your engine systematically. Did you check fuel pressure? Fuel filter? Connect a scan tool, look for codes, at live data, fuel trims etc. You provided such little imformation that it is difficult to tell you what is wrong. Why did you replace the injectors in the first place? If it was for the reason you listed, you replaced one of the very least parts that would ever go bad.
andy1019
Jul 7, 2011 04:54 PM
riptero
Feb 18, 2010 05:34 PM
McJerky
Jun 8, 2008 12:30 AM
pizzamon
Apr 13, 2008 03:40 PM
cocoakarla48
Oct 9, 2007 12:19 PM
