-   Ford Ranger (https://www.fordforum.com/forum/ford-ranger-16/)
-   -   Removing rear-view mirror (https://www.fordforum.com/forum/ford-ranger-16/removing-rear-view-mirror-1706/)
Dr76 Sep 5, 2005 05:21 PM
Hello, first post here and a basic one at that...
Need to remove & reinstall the rear-view mirror in my '93 Ranger and not sure of the best way about it. Anything to dissolve the "adhesive"? Heat?
Mine is WAY-OFF center and it drives me nuts (passenger sun-visor hits it...it's that far off!)
Thanks! :)
Ramrod48 Sep 6, 2005 03:18 AM
RE: Removing rear-view mirror
I would remove the mirror its self , has that lil allen in the middle of it , leaving the small Alum. disc thing , Take a good sharp wood chisel , an place its edge against the mirror an the bracket , like your going to shave it off , An give it a tap with a hammer ( tap light ) it should just pop off
that way. Then get a razor blade remove glue from glass , an from the disc.clean up the glass an disc with some alchol ,, Use like a Black magic marker, on the out side of the windshield where you would like for the mirror be , draw a small circle, Then Apply the glue as directed, Stick on the disc. hold in place for a few minutes, Then let it set up over nite an install the mirror the next day ,, dont forget to remove the magic marker from the outside of glass , same deal , use razor an alchol, Thats all theres is to it ,Ive never had one fall off this way ...
Dr76 Sep 6, 2005 09:23 PM
Great...thanks for the very detailed process!
Ramrod48 Sep 8, 2005 12:11 PM
Hey , Thats why we're here , come back anytime , you might be able to help the next person , We all have something to add !!:)
anji Jul 30, 2010 10:25 PM
Rearview mirror
Maybe a dumb question, but how do you get the aluminum disk off of the arm of the mirror?
