Strange emmissions
Old Aug 28, 2009 | 10:04 AM
CJG86's Avatar
Default Strange emmissions
While driving the engine will start to loose power and will start puffing
fuel rich (black ) exhaust. Changed o2 sensor and fixed for about a week
open to any suggestions. Have already considered that i got a bad bosch o2 sensor
Old Aug 28, 2009 | 10:08 AM
CJG86's Avatar
Forgot to tell you that i have an 1986 ford ranger 2.3 nom turbo
Old Sep 3, 2009 | 08:12 AM
Use Common Sense's Avatar
It wouldn't suprise me if it was bad. I always use OEM for all sensors. Even if the aftermarket sensor is made by the OEM supplier, the EOM quality control is different. A lot of times, the aftermarket part is an OEM quality control "FAILED" unit.
Also, check the wiring and connector. Make sure the wiring isn't rubbing some place. A short in the wiring can also cause the same issue.
kerwinq
Apr 16, 2007 11:09 AM
Rikymaru
Jan 26, 2007 09:52 PM
lucasleigh
Jan 25, 2007 02:28 AM
MXDAD503
Nov 10, 2006 08:33 PM
F250LOVER
May 23, 2006 12:32 PM
