Troubleshoot power seats?
I have a 2004 Sport Trac and both power/heated seats (with lumbar) no longer work. The seats do not move, do not heat, and the lumbar pump does not run.
I've looked under the seats and have checked and reconnected all cable harnesses I could find (there appear to be 3 for each seat) and that didn't help. I also checked the auto-resetting breaker under the hood by disconnecting the battery cable, pulling the breaker & testing the pins with a continuity tester, it's fine.
Does anyone have a wiring diagram or troubleshooting tips for the seats? I was going to start testing the wires for power/continuity but am not sure where the best place would be to disconnect under the hood or dash, and which wires should have how much power.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
So all power seat adjustments work correctly now. Your issue is the heated seats do not work, I assume you are talking about the driver seat, does the passenger heated seat work? Does the heated seat switch respond to being turned on/can you hear a relay click on?
2004, expedition, f350, ford, issue, olds, power, seat, seats, seats2004, sport, trac, troubleshoot, troubleshooting, van
