02 Taurus 3.0L Chirping Noise
Old May 23, 2006 | 11:25 AM
dustris's Avatar
Default 02 Taurus 3.0L Chirping Noise
I have a 2002 Taurus (Sable), 3.0L OHV, with 80k. For the past 10,000 miles, it has been making a "chirping" noise...(not a belt). I have determined that it is (90% probability) the Camshaft Synchronizer.
I set an appointment with the Dealership this A.M. to get it replaced, and WOULDN'T YOU KNOW, the noise quits this morning, and doesn't come back, even after a 60 mile commute!!?!?!?
Here are my questions: Is it possible for WHATEVER is making this chirping noise in the Camshaft Synchronizer and Sensor to safely STOP making this noise after a period of time (maybe the parts rubbing together "wore down" a little!?!?)? If this part goes out completely, (maybe that is why it quit chirping), will the car still run? It appears to be running FINE.
Also, this appears to be a problem Ford is aware of with the 3.0 motor. Are there any TSB's or ways to get this fixed by Ford at NO CHARGE, since apparently this is a faulty part? Any tips or experiences on this one?
Old May 23, 2006 | 09:20 PM
hockeyhitman69's Avatar
Default RE: 02 Taurus 3.0L Chirping Noise
its very possible to be that or could be tensioner you would have to remove belt when it is squeaking or chirping to narrow it down
Old Mar 27, 2007 | 01:45 PM
trdoc's Avatar
WOW! I am so glad I found this post!
This is the EXACT problem I have been having with my '02 3.0 Taurus. I was told at AutoZone that it was the Camshaft Sequencer (maybe it was Synchronizer). I cannot find the part in their online database, although they showed it to me as a part in their store computer, for about $60.
My noise is variable and it comes and goes alot. Mostly seem to notice it in the mornings.
Someone help me here, I don't know what to do, I'm afraid this could cause me major problems down the road, and I want to be able to go to a mechanic with some kind of knowledge on the subject, so I don't get hosed. I'm new in town and haven't had an opportunity to get a relationship established with a local garage.
Please someone respond to this and give us some more information!
Also, I should say, this is definitely not a tensioner, the noise is not coming from the belt area at all. I have checked the belt and it is in good shape, the noise is coming from inside the engine on the driver's side... nowhere near the belts.
Old Sep 19, 2007 | 01:09 PM
tomb1269's Avatar
The Ford Taurus, Sable and Rangers from 2000 thru 2003 can have a hesitation bucking over 3000 rpm due to the syncronizer. No trouble code will display as the fault circuit for the cam sensor is not monitored over 2500 rpm per Ford TSB. To determine that the syncro is the problem the knock sensor is monitored, it should read 125 or less if the syncro is bag it will register several hundred to it's limmit of 1023......The syncro can also sound like belt squeal when it starts to fail.
Old Sep 19, 2007 | 01:14 PM
trdoc's Avatar
I had my camshaft synchronizer changed out and my problem was gone. They called it the 'crank angle sensor' at the shop, but it was the same thing, essentially. Very pleased after replacement.
However, now while traveling at highway speed, I occassionally feel a slight hesitation and perhaps hear a tiny 'squeak' from under the motor. This only happens maybe every couple of minutes or so... is this the same problem you're referring to? Is it possibly related to the same part? It's a very very tiny hesitation, but once it's been pointed out to people, they usually also feel it, too.
makuloco2000
Jun 16, 2014 11:30 PM
thepopeis1
Jun 17, 2009 05:27 AM
No Harley Here
Jan 1, 2008 08:59 PM
woofan6
Jun 28, 2007 06:57 AM
DKEYSER
Feb 5, 2007 12:54 AM
