1988 taurus wont start
Need to get help on what could be the issue with this car. My Wife was driving this car and it just quit. Pulled it back home and there is no spark from the coil.
Coil, Ignition Control Module, ECU/ECM and 200 bucks later still no luck starting the car. I have used the How to Test the Ford Ignition Control Module to trouble shoot the problem and the PIP is working. There is no voltage change on the Ignition Coil Control Signal lead. I need more ideas on what could be the problem. Pulling my hair out at this point. :mad: |
Originally Posted by cewill99
(Post 71894)
Coil, Ignition Control Module, ECU/ECM and 200 bucks later still no luck starting the car. I have used the How to Test the Ford Ignition Control Module to trouble shoot the problem and the PIP is working. There is no voltage change on the Ignition Coil Control Signal lead. I need more ideas on what could be the problem. Pulling my hair out at this point. :mad: HTH ... |
