2007 Taurus bucking
Glad you figured out that TPS is for Throttle Position Sensor. I've seen a lot of the TPS issue mainly in vehicles that drive pretty much consistent speed in city driving. I first experienced it myself (seems like eons ago) in our old 1983 Mid Sized LTD.
do you think when I purchase a new sensor the issue is solved? And can O do it by myself
A new TPS may or may not resolve your problem. You can use a Digital Volt Meter and Ohm out the pins to see if you can detect a short (0 Ohms) in the TPS. Or just go ahead and throw a new TPS on. The TPS is mounted with only 2 screws and 1 electrical connector.
thx there is one thing I want to mention and yesterday I was driving on the highway bucking again I did put my car on cruise control and he was driven smooth without bucking
I want to thank the people who gave me advise I did change the sparkplugs and my problem is gone it drives smooth again great thx Kulmbube
Good morning I have a ford taurus sel 2009 , my wheelbearing rear R is making a terrible noise so I have to replace that piece my question is: can I go and change only the bearing (by a specialist) or do I need to purchace the complete hub thx
If you have a vehicle with 4WD you need part number 8F9Z-1104-A, this part works on both the LH and RH side. We have it available for sale here: #8F9Z1104A: Hub. Hub & bearing. HUB & BEARING ASSY. Hub assy.
If you have a vehicle with 2WD you need part number 8F9Z-1104-B, this part works on both the LH and RH side. We have it available here: #8F9Z1104B: Hub. HUB & BEARING ASSY. Hub assy.
expo1998
Aug 9, 2007 11:06 AM
