2007 taurus vulcan - clicking under load
If the grooves in all the grooved pulleys are clean , you might have to give back the belt if the noise goes away when sprayed with water.
Have any of the components the belt drives been replaced? If there is an alignment problem it could contribute to belt noise.
I took off the belt to inspect things this weekend. I have not replaced anything in this system (except the belt last year). I can't see anything wrong. I spun everything that I could spin and checked for side-ways movement, but nothing obvious. I did try and clean everything, thinking road grease/oil could be having a negative effect. It quieted everything down a lot. Unfortunately, it is very hard to get into that tight area and do a good cleaning!
ken441959
Canada, Over Seas & Elsewhere
Jan 23, 2006 07:01 PM
