2011 SHO question
Old Feb 10, 2013 | 09:17 PM
  #11
FordLifeSaver's Avatar
Originally Posted by kiliki
Thank you for the info. My build date is May 2010 and have 16k. Does this help/change anything you said. And I will present this EXACTLY as you said. I will not sell you out.
What is DTCS?
(DTC'S) DIAGNOSIC TROUBLE CODES, since if you state the check engine light came on and went off they may be suspicious enough to scan your system and lead them to find something.
Old Mar 13, 2013 | 06:52 PM
  #12
kiliki's Avatar
Got the car back and here is what they did:
Missfire:
replaced 6 spark plugs
replaced coil assembly
TSB 11-8-19
Brakes:
(Squeaking in reverse was problem)
TSB 11.5.15 applies, performed TSB, turn rotors, replaced caliper mounts & pads
Thanks for the help
wrocky
Sep 21, 2012 08:17 AM
SRB64
May 19, 2012 05:59 PM
cardiag12
May 16, 2011 03:01 PM
freshusmc
Sep 1, 2008 09:15 AM
