91 tauras SHO
just bought a 91 tauras SHO took it down the road ...FAST and when i redlines and went to shift into 2nd the car began to spit and sputter and then stall and since then it will not start it will turn over but not fire ...checked and theres no spark... maybe the distributor??? are the disributors on SHO's the same as off a reg. tauras?
RE: 91 tauras SHO
Check the fuse for the ignition:)
RE: 91 tauras SHO
thanks looked in the fuse box under dash changed 2 but still the same result is the ignition fuse in that box or in another location?
RE: 91 tauras SHO
Under the hood should be a power distrubition box with fuse's arn relay's for the computer,ignition,ect
RE: 91 tauras SHO
ok thanks ill check that out in the morning ...any other things i should check?
RE: 91 tauras SHO
Mabey any loose wire's. [ul]
[/ul]By any chance when you were driving it did the check engine light come on? |
RE: 91 tauras SHO
Sounds like a blown head gasket.
RE: 91 tauras SHO
did the Tach quit working if so
check the crank sensor |
