91 tauras SHO
Old Aug 13, 2006 | 05:25 PM
hoosierdaddy88's Avatar
Default 91 tauras SHO
just bought a 91 tauras SHO took it down the road ...FAST and when i redlines and went to shift into 2nd the car began to spit and sputter and then stall and since then it will not start it will turn over but not fire ...checked and theres no spark... maybe the distributor??? are the disributors on SHO's the same as off a reg. tauras?
Old Aug 13, 2006 | 05:40 PM
94 4x4 ranger's Avatar
Default RE: 91 tauras SHO
Check the fuse for the ignition
Old Aug 13, 2006 | 09:35 PM
thanks looked in the fuse box under dash changed 2 but still the same result is the ignition fuse in that box or in another location?
Old Aug 13, 2006 | 11:16 PM
Under the hood should be a power distrubition box with fuse's arn relay's for the computer,ignition,ect
Old Aug 13, 2006 | 11:35 PM
ok thanks ill check that out in the morning ...any other things i should check?
Old Aug 14, 2006 | 01:07 AM
Mabey any loose wire's. [ul]
[/ul]By any chance when you were driving it did the check engine light come on?
Old Aug 24, 2006 | 08:27 AM
RandysFT's Avatar
Sounds like a blown head gasket.
Old Sep 7, 2006 | 07:01 AM
grizz's Avatar
did the Tach quit working if so
check the crank sensor
ledbo8
Mar 4, 2009 02:37 PM
Bill/Carson
Apr 22, 2008 06:53 PM
mzmanniefresh
May 14, 2007 02:45 PM
dilligaf58
Sep 12, 2006 06:55 PM
Will
Apr 26, 2006 11:11 PM
