92 taurus se
Old Jun 11, 2006 | 12:02 AM
waldoranger's Avatar
Default 92 taurus se
How good of a car is the 02 taurus se. i just bought one with 63000 on it are they good cars or should i expect to be changing some things. i have put 100 miles on it since i got it. it seems fine so far. anything i should expect??
Old Jun 11, 2006 | 05:14 AM
Mulletman's Avatar
Default RE: 92 taurus se
If you got an SE, I am assuming you have the 24Valve 3.0L which is a pretty decent engine. Not too many problems with those cars except the crappy link pins that make a "Clunk" noise over bumps and trying to keep the coolant clean.
Have a dealer run the VIN for recalls though. The coil spring recall (04M04) is pretty important if you live in the NE are of the country where salt is used on the roads. I also think that year had the stop light switch recall on it. Check it out.
Old Jun 12, 2006 | 05:43 PM
thanks mulletman. i check on that.
Old Jun 22, 2006 | 12:06 AM
billybroncojr's Avatar
I had a 94 with 225k on it, and a 95 with 140k on it. Ended up rebuilding the 94 3.0 and putting it in the 95. I now have 4k on the rebuild and everything is going ok. Like Mulletman said the coil springs on both cars needed replaced, but other than that I couldn't be happier with them!
Jeff
Lars(wi)
May 29, 2013 07:22 PM
blixx003
Apr 11, 2007 11:05 AM
blixx003
Aug 14, 2005 03:42 AM
